Results 1 to 5 of 5
Thread: OK What The #$%^ am i doing wrong
    PERTH
    haha got ya attention now help me...
    my problem
    when box is attached to the block and the main 3 box bolts are put in. my clucth is not dissengaging as the clutch cable lever will go half way up and stop.... basically the clutch rod wont push the release plate it seems to get there and just stop, ive bought as new full complete clutch and newish box so im rulling them out. new clutch cable, im 100% sure i got the friction **** centred..... might be pressure plate to tight?
    the engine is new and has been running in car befor, havnt driven it since new clutch and new box
    my previous attempt resulted in being able to start engine but not select any gears..
    has any body exprienced this or know what my problems are other than im a crappy mechanic for not finding whats wrong.........
    LET ME BLOODY KNOW
    i bet its simple
    bonza
    the golf is not dead.
    Camden, Sydney
    Tighten up your clutch cable to the max, use a wheelnut or similar spacer ( for testing purposes ). get the proper rubber washer eventually :roll:
    You should push the arm up till you feel pressure, then tighten the cable.
    Have a few goes and you may need to tighten again.
    Hope that helps, sounds like you`ll be rolling soon.
    Nov 2005
    newcastle
    if your trying to operate the clutch lever with your hand... it wont work... you'll just have movement until it takes up slack, and it'll feel solid... i had the same scare when i changed my clutch too...
    as loon said, tighten your clutch cable and only use the pedal for testing
    TDI mk1 on the road!!
    PERTH
    sweet i knew that......
    gee that was kinda easy..
    ok done next step gearbox oil/
    Camden, Sydney
    Just awaiting for the update that says you are hooning round in a working 16v
Similar Threads
  1. What would go wrong?
    By SOHC in forum Mk3 Golf & Vento
    Last Post: 06-10-2006, 12:20 AM
  2. Something wrong, but I don't know what !
    By RedMk2Gti in forum Mk2 Golf & Jetta
    Last Post: 05-12-2005, 08:34 AM
  3. Slipping Belts - miracle solutions
    By Tameth_au in forum Mk2 Golf & Jetta
    Last Post: 05-11-2005, 10:26 AM
